No, that pulley in back of the crankshaft pulley is the timing gear for the timing belt, I hope you didn't damage it while you were trying to stop the crank from moving.
The flywheel is on the back of the engine, where the transmission meets the engine block. Remove the starter and you will see a big wheel with teeth on it. Stick a prybar in the teeth and have a friend break the crank bolt loose.
