Old 06-24-2007, 05:41 AM   #1
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
The thing is that with SS brake lines you have to buy the right kind because if you dont then they wont last. The brands that I would look for are either a set of OEM brake lines or if you go with some SS lines go with Earl's or goodridge because if you get some cheap ss lines you will get dirt between the metal and it will wear faster and get dirty and make sure that the ss lines have somesort of protective coating on the outside.
--Here is some info on the Earl's ss brake lines--
Serious race car owners have used flexible brake hoses of extruded Teflon™ for decades. They are protected against abrasion and swelling by a sheath of tightly braided stainless steel wire. The resistance to “lineswell” both improves the firmnessor “feel” of the brake pedal and reduces the time required for effective pressure to reach the brakes and begin to slow the car. Equally important in street vehicles, improvement in pedal firmness and feel make brake modulation easier and more efficient—right up to the time that the anti–lock brake system is actuated. The familiar brake pedal “thump” of anti–lock brake systems is significantly reduced. The decreased system reaction time reduces stopping
distance in emergency situations—as much as 18 feet at 80 miles per hour.
The Teflon™/stainless steel brake hoses have not been available for legal use on street driven vehicles until recently. All safety–related components on street vehicles must meet stringent requirements and tests set forth by the National Highway Traffic Safety Administration of the U.S. Department of Transportation. The most demanding test for brake hoses is the “whip test,” designed to simulate the continuous flexing of the hoses during suspension and steering movement. Until Earl's developed and patented their exclusive “whip dampener,” Teflon™/stainless steel hoses were not able to pass this extremely rigorous test. The D.O.T. does not “approve” any products. It calls out specifications and test procedures that the components must meet. The manufacturers then self–certify that they are in compliance. The D.O.T. may randomly require that components be tested by an independent certified laboratory selected by the D.O.T.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
