A/C question
I have a 90 NA the air worked great untill yesterday,the clock quit the same time.The switch in the cilmite control seems to work,it still turns on the cooling fans(radiator) but won't engage the clutch.I put a volt meter on the a/c plug no voltage.When I put 12 volts to it the clutch engages.I have checked all the fuses yes even the one on the passenger side for the a/c they are all good.Would I risk damaging something if I wired the compresser to 12 volts with a toogle switch,or is there something I am missing?
Please Help!
