what is all the fuel parts you have to remove I have unhooked to injector plugs but not removed the injectors yet but do you have to remove the fuel rail and all the hoses because I did not see that in the haynes manual but I might have read it wrong and for the head can you tap it gently with a soft hammer instead of using a pry bar and maybe mest up something
