Old 06-27-2007, 11:38 PM   #18
IHateHacks
IHateHacks's Avatar
On a 7M, when the oil is under 190 degrees the pressure will be just below 40psi when driving and around 25-30psi when idleing.
When the oil is up to normal operating temp, 190+ degrees, oil pressure should be around 10psi at idle and just below 40psi at 3000rpm or higher.
Try replacing the oil pressure sending unit, its worth a shot.
