Old 06-29-2007, 08:22 PM   #3
zuni
zuni's Avatar
zuni is on a distinguished road
Originally Posted by cre
Tighten down the throttle cable. There is supposed to be a little slace, but not 1". Mine has about 1/8" of play. Then recalibrate your TPS. You can try experimenting with timing advances. Make sure your cat is partially clogged with debris as well and check your plugs and wires.
How do you recalibrate your tps? and what is a tps? and whats timing advances.
zuni is offline   Reply With Quote
