Originally Posted by IHateHacks
The only reason the overflow "overflows" is from a combustion to coolant passage leak, better known as a blown head gasket. Your symptoms are dead accurate.
Just did a head gasket repair and mine dosent do it anymore, The water jakets on the head were eaten up small leaks in the gasket!! replaced everything that could have caused the problem, but it was a head gasket
