Originally Posted by 2jz lexus
i want to get 450rwhp on pump gas
Nope, that can't be done with the oem twin turbos (not safely/reliably anyway), unless you want to spray nitrous. To do it on boost alone, without hurting your engine, you'll need a single turbo kit on your 2jz-gte, and an AEM (so you can retard the timing curve enough to hit 450rwhp on pump gas). An SP59GT may achieve that result, if it's a manual transmission. With an auto tranny, you may need an even bigger turbo (eg. SP67) and a full fuel system upgrade to get 450rwhp on pump.
If you want to spray nos, let me know and I'll advise you on the setup. Also confirm 6spd or auto...
Why won't you consider meth or race fuel? A few gallons of race fuel is much cheaper than a single turbo kit...
