go here it gives you an explaination of what it is. http://www.aempower.com/ViewTopic.as...=25&menu=falseIt is more set up for drag racing and letting you get your launch perfect by setting a rev limit of what your best launch RPM is if you drag race a lot I would go for it but if you are into drifting or SCCA autocross like me it is of no use then.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
