will do, and the best places you can find these parts are the junkyard or the parts wanted section of the forum some parts are recommended you buy new such as bearings, the clutch, shifter bushings, and the flywheel buy you can get the flywheel machined, if youre really unfamiliar with the swap do your research on it before anything, ive been researching and gathering parts since early may and i still havent done it, but i plan on doing it as soon as i get a release fork. it'll help alot of you had a TSRM too as it will tell you step by step on removal and installation
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
