I doubt anyone took you as hostile. We all know the frustration when you get so close but can't clear that last hurdle. Before you run out and buy a new MAF box I would recomend you get those diagnostic codes. Double check the vaccume lines for leaks ,check that your timing belt in installed to correct tollerance ,and the distributor is properly set.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
