I have the HKS super dragger and it makes the horsepower go up a conciterable bit but it costs like 700. It has a nice low note and it isnt very abnoxious. Also I have put in a test pipe and gotten rid of my cat. The front pipe that you can get check ebay the have people that make them and also there are ones made from top manufacturers they aint cheap though. Also they are a bitch to put on that is why mine is still sitting because I havent had time to take all of the turbo manifold off to put it on. The reason for the complete removal is the turbos had studs sticking out of the exhaust and to get the y pipe out (which by the way is very restrictive and it gives you a nice horsepower boost just changing it out) you have to remove the front turbo because dont even think about taking out the back one I dread it. here is a greddy down pipe http://cgi.ebay.com/ebaymotors/Gredd...QQcmdZViewItemand this is the one I have https://935motorsports.com/catalog/p...oducts_id=1018
you just got to look around and do some research.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
