Sounds like your crankshaft timing sprocket is messed up. The cogged pulley that goes on the crank behind the aluminum lower timing cover that the timing belt is driven by.
Nothing is torqued to 75ft/lbs down there. Crank pulley is 195ft/lbs and the timing belt tensioner is 36ft/lbs.
