Old 07-11-2007, 05:53 PM   #2
supradaddy0803
supradaddy0803's Avatar
I ran into the same problem with my 1JZGTE swap the different connectors are a easy fix just have to find them and splice them into your wireing harness. If you go to a dealership and take the connectors they should be able to get them. I lucked out because I had a clip and just cut off the ones I needed. As for wiring them there is quite a few people out there that have a wiring diagram that will work for you the colors should be the same just in different places on the plugs.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
