well i looked a little closer, and one of the IC pipe couplers had a tiny hole in it, i dont know if that was the problem yet but ill find out on the way to work today  if it is home depot here i come. i found that the rubber couplers they got down there at home depot for toilets work great. and there only like 1.25
7MGTE - 500hp  never dyno'd
fidenza cam gears
