Yes the green part connects to the dash. That one has both parts, the longer piece and the shorter pigtail that connects to the transmission.
I just went through this and had to replace mine because of my pacesetter headers. Apparently the heat after I wrapped them with header tape melted the inside of the cable and it froze. I put a new cable on and it still didn't work. When it froze it also froze the gear inside the transmission which is a plastic gear and it wore a grove in the center of it and it was stripped. After replacing that it works fine. I also wrapped some heat tape around the cable where it runs above the headers to keep it from melting again.
