well that wasnt the problem. the best way i can describe it is it sounds like when the turbo kicks on the bov starts to open, cause i have noticed that i can barley hear the bov anymore. that or the IC pipes do have leaks and i just dont see or hear them, at idle the bov is closed. but i have noticed a hiss sound from under the car near the oil pan, i have heard this sound for a while even in the past but the car had worked fine with this noise in the past. any other ideas?
7MGTE - 500hp  never dyno'd
fidenza cam gears
