oh believe me the rubber hose coupler from home depot worked awesome, its just that pipe had blown apart so many times and i have had to keep loosening and tightening the band clamps, then i upgraded to a T-bolt spring loaded clamp, but yea i have just tightend things so many times its torn a hole, and that little hole because a bigger hole from the coupler expanding.
7MGTE - 500hp  never dyno'd
fidenza cam gears
