Thread: 1000 rwhp
Old 07-16-2007, 03:25 AM   #8
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by JPDsupra
Ok so 116 octane fuel, what turbo size and what kind of turbos would you recommend...
For 1000rwhp (6spd) you'll need a 76mm turbo. Sound-Performance is a great company to choose, since they've pre-matched & tested both the compressor and the turbine a/r to the needs of the 2jz-gte.
...and what would be any company that does the type of fuel system upgrade that I need to run...
Sound Performance also sells fuel systems. I used to make and sell them too, before I started working 12+hr days at my new job...
...and what other adjustments like strengthening the block...
Again, only the connecting rods need to be changed over 850rwhp. Everything else is just fine for 1000rwhp.
...or anything else I would need...
You'll need a different intake plenum - the oem plenum is only flow balanced to about 750rwhp or so. I like this one, by Virtual Works.
...btw how much does 116 octane fuel cost?
I'd guess about $9/gal...
Life begins at 30psi.
