your fan clutch it the aluminum piece between your fan and water pump. to test it get the car hot and turn it off, you should not be able to turn the fan.
the smaller fans are for the A/C, which wouldn't really have anything to do with an overheating problem.
is there sufficient flow to the radiator? like is there shit in front of it that would cause it to get no airflow?
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
