well i did some searchese this is what i found
http://toyotaownersclub.com/forums/i...howtopic=39095
http://www.supramania.com/forums/showthread.php?t=386
7mgte removal of charcoal canister and EGR
Now remove the vacuum hoses that are highlighted in red. And cap off the vacuum ports that I highlighted in green. That’s all there is to it for a stock setup.
as for the blocking off i was reading a little more on this, if i got this right the right red circle you want blocked off. but as for the right one you dont want to block off, the 2nd block off goes onto the intake plenum heres a pic of that
7mge removal of charcoal canister and EGR
Same thing as before. Red are the vacuum lines you can remove and the green is the places to cap. And the blue dots are pieces that you can remove.
"NOTE"
i got all this information from other peoples post, so dont try to think im smart
7MGTE - 500hp
never dyno'd
fidenza cam gears
