i just fixed my speed, its got two parts to it. theres a cable that runs from the dash thru the fire wall(thats the worst part of getting it in) it runs down behind he downpipe and the under the chassis up to the tranny. at first it was the cable that goes to the tranny(the cable becomes two under the chassis) it was snapped because the second half going to the dash was locked up and wouldnt spin which i found out by putting a replacement in and snapping it as well. just spin the cables and make sure they move. spin the longer cable going to the dash and have someone check to see if the tach moves, pspinning the wrong way will result in no movement so try both. hope this helped. any more questions bout it just ask and ill help with what i can
