Old 07-18-2007, 09:18 PM   #11
supradaddy0803
supradaddy0803's Avatar
The only thing it will make easier is with the clip you will get the plugs you need under the dash and the hood that have to be swapped so all of the dash and EFI harness will work. But as for those if you can find the part number for them I am sure you can get them from the dealer and the pins as well.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
