Old 07-20-2007, 12:23 AM   #14
supradaddy0803
supradaddy0803's Avatar
I ran my harness through a new hole in the firewall under the speedo cable and behind the heater core and it reaches just fine in the stock location. But if you want to solder like 170 wires you go right ahead.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
