Originally Posted by JPDsupra
Forget the handling part its just gonna be a weekend Drag racer...
Ok, now to do
easy 9s you'll need slicks, skinnies, and a TH400.
...and when I said "nothing extreme" I meant like suspension wise just so it will be able to turn right and wont kill my back when' i go over potholes....
A stiff suspension is only for roadracing. For drag racing you want the @ss end to squat down, and you completely disconnect the front sway bar.
...Would it be a good idea to take weight out of the car cuz I know that less weight equals more speed but sometimes it means less traction...
If you want 9s or 8s, yes remove weight. To get traction you need tires (aka slicks & skinnies), not less weight. For example, if you run low-profile roadrace rubber on the rear, you'll spin no matter how heavy it is.
...One of my freinds told me not to take weight from the back instead from the back though the supra is a relatively heavy car not bimmer heavy but heavier than a 350z or an evo or sti...
Take out weight wherever you can, for faster times. For example, it's good to relocate the (heavy) car battery to the rear, but it's even better to move it to the rear AND replace it with a lightweight drag racing battery.
...By the way I have about 60k scrapped up right now that I can spend for modification (I already got the car) I think this will easily get to 80k+ but it all depends on what I do
Agreed - high 8s will be a
lot more expensive than high 9s, for example.
