i really dont know, the way is see it is power to weight will give you most of your answer. the DMV said that my supra weights 3970lbs and i have only added 2 12" subs. i dont know what the stock HP is on a turbo supra. but if it has an intake and full exhaust it may have an extra 50-70hp. then shimming the wastegate to get about 10-11lbs of boost instead of 6.5lbs that will give you a tad bit more power. then your set.
i mean i have
lightweight flywheel
6 puck clutch
shimmed wastegate
greddy rs BOV
3 inch turbo back exhaust - no cats
custom 2.5inch hardpipes upper IC
and it stays up with an STI and im still running the stock airbox
7MGTE - 500hp  never dyno'd
fidenza cam gears
