safely i think it is 15-17lbs on the stock head gasket. the engine itself can handle 500hp daily stock if i remember right. but you'll only be able to goto 12lbs of boost because at 12 you'll hit fuel cut the turbo itself can handle 15lbs to the houseing. post some pictures of the widebody im thinking of getting a widebody kit for mine.
7MGTE - 500hp  never dyno'd
fidenza cam gears
