and are you sure that it is the HG that is blown because i have a friend that had the same problem and it ended up just being the radiator cap. oil is black in color not milky, the exhaust is fine it doesnt feel slick, its not steaming at all. i mean overall the car seems good it just overflows coolant, and again when it was overheating the radiator cap wasnt steaming till i took it off.
7MGTE - 500hp never dyno'd
fidenza cam gears
