im still lost as to what a compression test is and how to do it.
Originally Posted by IHateHacks
No, you unplug the EFI fuse so you don't spray fuel in the cylinder while you test the cylinder compression. Liquids don't compress.
I agree, make sure the head gasket its good, then perform all maintainance. Timing belt, tensioner, fuel filter blah blah blah.
Then get a turbo back 3" exhaust, and coilovers. Get the best your money can buy for a supra, don't cheap out.
