Clutch Problem
87 NA. The car sat for 11 years first off. The engine blew so I put in a new motor. I put in a new clutch plate, pressure plate, throwout bearing, and pilot bearing. I drove the car for about a week and it did ok but there felt like there was a problem in the clutch or master or slave cylinder. When you press the clutch petal theres about 1 to 1 1/2 of freeplay and the petal feels spongy after the freeplay (it really hard to explain). So I bleed the line and allittle bit of air came out, but not much and the petal felt more firm. 2 days later its doing it again and when it does it it really hard to shift and almost impposible to shift to reverse without grinding. any suggestions
