Greddy BOV issue
ok first of all as you might know im doing about 10-11psi and on a rare time 12psi. but also some of you have seen the new IC pipe setup i have going. but my main issue is that my Greddy RS BOV is opening at around 4krpms during load. so driving on the freeway i can hear it whisteling while im driving. what you guys think i should do about this problem?
7MGTE - 500hp  never dyno'd
fidenza cam gears
