Old 07-30-2007, 06:22 PM   #2
supradaddy0803
supradaddy0803's Avatar
You can buy a 40k 7mgte pretty cheap and seeing as you are already have one then the swap is no big deal. I went the route of the 1JZ because I have a n/a 7m so all I could do is go up. Also the 1JZ swap gets expensive depending on what you get like a clip or just the motor.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
