Old 07-31-2007, 05:00 PM   #5
D_Train
D_Train is on a distinguished road
Originally Posted by dcrusupra
A loost temp housing definitely would. It would be leaking down the front of the motor. And it would burn off all the coolant while driving so while it would leak after you drive it, no coolant would be visible
Well in this case all of the coolant is showing on the front of the radiator. (thanks to the dye) but I think that it is just because it is coming out of the overflow tank and spitting onto the front of the rad. if there is a rad leak wouldn't it be on both the front and back of the rad? at least just a LItTLE bit?
D_Train is offline   Reply With Quote
