most likely (99%) its a head gasket cuz it is common with the mkiii due to the head bolts being under torqued from the factory. put some pics of it on here. you'll probably want to rebuild the engine or swap it out for another 7mgte and just replace that head gasket on the new one while its out. or go for the 1jz or 2jz. welcome to the forum you'll find a lot of help here.
