Old 08-02-2007, 05:30 AM   #11
mrnickleye
mrnickleye's Avatar
OK...I'll spill the beans. Mine did the same EXACT thing.
Block test showed no problems.
Finally (a month later) put the smog machine tailpipe tester probe at the open radiator cap while engine was idling.
BINGO.......a few hundred HCs. = BHG
All better now, 2.3 years.
PS: coolant goes into overflow bottle from engine, which leaves air is in the passages.
Over night the coolant should get sucked back into engine as it cools down.
