couple of questions
question one: key & ignition
alright so i have the ability to take my key out when i turn the car to acc or the ON possition car will stay running so will everything else steering wheel is unlocked an all, i then can use any key to turn the car off or if i just turned it to the acc possition then i can use any key or object small enough to fit in the ignition entrace to turn her over.
does anyone elses supras do this?
question two: rear end
ok so i dont know if my rear end is just weird or if its just doing its thing but it doesnt like to do donuts as well as i would have hoped. doing the outside tire spinning thing, 1 tire fire. pretty sure its just the right tire. but when doing a burnout im leaving 2 tire marks. its labled LSD on the back from a junkyard.
is this right then?
and is there an upgrade? if i remember right TRD makes one but is it any good?
7MGTE - 500hp  never dyno'd
fidenza cam gears
