Originally Posted by JPDsupra
Originally Posted by amin
hi I have 93 Supra NA and wana to convert it in turbo with a budget of 5k. it is possible if not then waht would be the best option to convert it in turbo.
Ok it is constly and inconveiniet to convert it to a Turbo youd have to change the whole engine and a turbo has a 6 speed manual and if you wanna make any horsepower you would have to spend a lot more than 5k.
Exactly what do you mean? Do you mean simply putting a turbo on it, or getting it up to full Mkiv TT specifications (including brakes, suspension, transmission, etc.???
FYI: Here's a kit that lets you put a turbo on an n/a ... but you still won't have a full TT spec MKIV when you're done:
http://www.boostlogic.com/xcart/prod...&cat=19&page=1
