well i drift also, but you have to say donuts are pretty fun to do
i also have been getting a new noise up by the front tires, mainly if im moving about 5MPH backwards and turning or doing a quick left to right turn. it makes a clunk noise almost sounds like the DP is bottoming out. or a CV joint type of sound. like CRRRRRR
7MGTE - 500hp  never dyno'd
fidenza cam gears
