hey just curious a lil about how your guys' tire pressure is, not that it pertains to supras alone but after i took it to oil change/car wash people they check the pressure and they put them all to 36-37psi... which i find fine for my front tires.. but i have dif size tires on the rear.. i usually base my tire pressure on or a lil before the max psi for the tire, is this wrong... cause the max on my rears is 51psi and they had at 36psi, when i usually keep at 47-50... cause i like to get less traction at times if you know what i mean
..i know the more tire that touches the better traction.. but i was getting fine traction the way i had it... any who, i was just seeing what errrrybody else was doing. thanks for any input.
