Tire pressure
Too much, or too less, pressure will result into an uneven wearing of the tire and it will probably reduce it's life by a little... here is something they thaught me at my job:
Under-inflation
If your vehicle's tires are under inflated by only 6 psi it could lead to tire failure. Additionally, the tire's tread life could be reduced by as much as 25%. Lower inflation pressure will allow the tire to deflect (bend) more as it rolls. This will build up internal heat, increase rolling resistance and cause a reduction in fuel economy of up to 5%. You would find a significant loss of steering precision and cornering stability. While 6 psi doesn't seem excessively low, remember, it usually represents about 20% of the tire's recommended pressure.
Over-inflation
If your tires are over inflated by 6 psi, they could be damaged more easily when running over pot holes or debris in the road. Higher inflated tires cannot isolate road irregularities well causing them to ride harsher. However, higher inflation pressures usually provide an improvement in steering response and cornering stability up to a point. This is why participants who use street tires in autocrosses, track events and road races, run higher than normal inflation pressures.
Gab
