I've gotta 7mgte in my 85 with a w58 trans. It's close to a direct fit with just a little modification. The wiring was the hardest part. There is alot of info about the swap on CelicaSupra.com. Also a lot of aftermarket support. If you want less headache and more support, then the 7mgte is the way to go. Not many 1j/2j swaps out there in an MKII, but there are a few.
Good luck with the swap,
Mark
