Old 08-10-2007, 08:04 PM   #4
89n/aA/T-2turbo5spd
89n/aA/T-2turbo5spd is on a distinguished road
Originally Posted by supradaddy0803
I ran into the same problem with my 1JZGTE swap the different connectors are a easy fix just have to find them and splice them into your wireing harness. If you go to a dealership and take the connectors they should be able to get them. I lucked out because I had a clip and just cut off the ones I needed. As for wiring them there is quite a few people out there that have a wiring diagram that will work for you the colors should be the same just in different places on the plugs.
I have one question for you, where did you get the diagram from? As I need one. My car was a 89 non-turbo, automatic, and I have switched it over to a jdm 7mgte 5spd. I just really need a wiring diagram, I can splice them together/solder. I was looking for a extension for the wiring harness, as the japanese wiring harness is too short, because it was from a right hand drive japanese supra.
89n/aA/T-2turbo5spd is offline   Reply With Quote
