Originally Posted by finaltable
I found out that the Pull-A-Part ten minutes from my office has two Mk III Supras right now. One is an '87 but the other is a '92. I'm going to see if either has the three piece wing I can snag.
Assuming these are there because they are wrecked, do I want to stay away from pulling a 5 speed + parts needed for an automatic to manual swap if one is available?
Also, what is the opinion on taking the turbo parts if the '92 is a turbo as well?
most of my 5 speed part were from the junkyard.the flywheel, pressure plate, master cylinder pedals and stuff, and the tranny itself was only $60, junkyard parts save you a lot of money.
