Cold Start System
Im having difficulty starting my supra and i think the cold start injectors arent working right. When i turn the ignition, the engine cranks ok but i have to give it gas and once it starts i have to keep feeding it gas until it warms up a little. Does it make sense that faulty cold starts could be causing this problem?
If so how can i check these myself, i think ive found the sensor (its on the thermostat underneath the bsvs correct?)? Should i replace the injector or clean it? and where exactly is it?
Thnx
