Old 08-16-2007, 05:26 PM   #12
supradaddy0803
supradaddy0803's Avatar
Ok the mounts you got if post 89. You will need Downpipe, plugs for under the dash and the hood (there is three under the dash and 1 under the hood, electric fan, Fan controller (so much easier than finding all the stuff you need for the hydro fan), MAP, ignitor box, intercooler, piping for intercooler, intake pipe with filter housing, 2JZ power steering line with the two banjos get it at driftmotion, a really helpful vaccum diagram (I can help you out there), 1/2 inch hose for the heater hoses in the back of motor, better boost gauge, Maybe a tach depends mine stopped working, And KY to squeeze it in it is kind of a tight fit. As for your other questions you dont have to extend the harness drill a hole under your speedo cable and run it in and behind your heater core and the harness is long enough. As for the plugs under the dash you might have to go to the stealership or I think driftmotion makes a adapter pigtail for them. Also you will need a really long cable to go from your fuse box under the hood to the alternator because I am sure you have noticed it is on the other side now. For the Downpipe I would just go buy a HKS 3 inch because you get a y pipe and a down pipe and swap that out when it isnt in the car beleive me heed my warning.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
