Old 08-17-2007, 01:36 AM   #5
supraman121
Originally Posted by j3pz
the coil packs and cam positon sensor (cps) replace the distributor. and for the injectors, if you dont replace them, you will run lean and possible blow the motor.
O ok well then i will end up getting the 550's with the other thing needed lol, and how hard is it to install the coil packs and the cam position censor?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
