most service manual will just tell you the home mechanic should just be concerned with the fluid level. but have you check your entire drivetrain? my car had really bad vibrations when i had an automatic and i thought the tranny was to blame but it turned out to be worn out u joint on the driveshaft, so check the rest of your drivetrain too.
you understand all these terms right? when i talk to my female friends about cars they dont understand much of anything so i dont even bother anymore if it just bores them.
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
