well if your really bad luck, your fuses and relays didnt do there job and just melted like mine tend to do.
other wise i say take a look at the relay box under the hood by the diagnostics box. bet you blew the acc relay.
7MGTE - 500hp  never dyno'd
fidenza cam gears
