How long of drive do you have? You can always just take the belt off but that is up to you it will suck to steer when you are sitting still but when you ae moving you will be fine. There is three belts on the motor one for the alternator, one for the a/c and one for the power steering. How much of a delay is there when you rev it if there is too much then your ignition timeing may be off a bit shouldnt be any at all really. Ask the guy when was the last time he changed the distributor cap, rotor, and plug wires, and plugs it may be due but wires arent cheap.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
