Which boot are you talking about the one where the tie rod connects to the steering or the cover where it connects to the rack? The one on the steering is a ball joint like the upper and lower so it is grease filled with a ball. The other is a dust cover to keep crap out of the rack.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
